1998 Chevy Blazer 4X4 problem
Old Jul 6, 2009 | 06:37 PM
bcn's Avatar
bcn
bcn is on a distinguished road
Default 1998 Chevy Blazer 4X4 problem
Blazer will not shift into 4 hi or 4 lo. 4 hi button blinks and goes back to 2 hi. Tried disconnecting battery, but same issue after reset. Checked wires at TCCM, but seem okay. What is bad? TCCM?
Old Jul 6, 2009 | 08:00 PM
3-button or 4-button 4wd dash switch?
Old Jul 7, 2009 | 05:18 AM
bcn's Avatar
bcn
3 button
Old Jul 7, 2009 | 05:37 AM
billymac49's Avatar
billymac49 is on a distinguished road
the computer sees that the transfer is not completing a shift. can be mechanical or electrical problem. encoder motors are known to go bad.
Old Jul 7, 2009 | 09:18 PM
Before you assume the encoder motor is the problem, run through the proper testing. Start with getting the codes from the TCCM (OBD2 Non-Automatic Transfer Case Diagnostics). It could be corrosion at the encoder motor. It very well could be an encoder fault, but it is easy enough to check the codes.
Old Aug 13, 2009 | 08:04 PM
Katmandu's Avatar
Katmandu is on a distinguished road
Question
I just bought a 99 Blazer a couple hours ago with this same problem. Mine has the 3 button switch.
#15 Fuse keeps blowing out (for the 4x4).
What does TCCM stand for ??
I assume the encoder motor is which does the actual shifting in the transfer case ?
Old Aug 14, 2009 | 10:37 AM
TCCM == Transfer Case Control Module
It is the brains in the 4wd system. It is located behind the passenger front kick panel.
Stucker92
Apr 26, 2014 08:06 PM
FPetro
Nov 4, 2011 10:48 PM
walkingtall
Oct 8, 2006 07:19 AM
