1998 Chevy Blazer LS 4 Door 4x4
Old Apr 26, 2014 | 08:06 PM
Stucker92's Avatar
Stucker92 is on a distinguished road
Default 1998 Chevy Blazer LS 4 Door 4x4
2 years I've had my Blazer with no substantial problems; except the steering. I have read many forums on this Blazer issue. Where the steering is sloppy and the only solution to this problem is "changing your steering gear.' I've changed my twice and believe it, or not; the problem is still there. I've checked all the other steering components, and even changed the pitman arm along with the steering gear; as one should when replacing the steering gear. All the nuts and bolts are at the correct torque specifications. Tomorrow Sunday, April 27, 2014 I'll be getting a new steering gear box and pitman arm to do this repair again. And yes the rag joint and tulip joint are both fine, but I will be changing the steering shaft all together with a Flaming River steering shaft. Who else has this problem and is stuck to deal with it?
FPetro
Nov 4, 2011 10:48 PM
Silock
Jul 25, 2011 03:43 PM
travisrussell88
Jul 6, 2010 07:46 AM
bcn
Aug 14, 2009 10:37 AM
walkingtall
Oct 8, 2006 07:19 AM
