1999 Blazer 4x4, Auto, Timing Solved.
Old Apr 27, 2022 | 02:06 PM
mojave.joe's Avatar
mojave.joe is on a distinguished road
Default 1999 Blazer 4x4, Auto, Timing Solved.
Howdy Fellow Blazer Enthusiasts,
I have a 1999 Blazer 4x4, Auto, 169K. I recently replaced the distributor, cap, rotor, plug wires, plugs, and timing chain to solve a P 1345 error. The chain and distributor were both worn and the chain jumped a link. Yay, I did solve it... but I had hell getting it restarted.
Here is what I learned...
  1. Forget the timing marks, whether you have one or two. I tried for days to use those marks in every possible configuration. They never lined up with anything significant.
  2. I verified TDC #1 using an inspection camera.
  3. Setting the cam and balance shafts with the dots together, like in the manual, and the arrows of the crank and cam pointed at each other (see image) sets up the engine to be at TDC on the compression stroke for cylinder #4. If you stab the distributor now your engine will NOT run.
  4. You must be at TDC on the compression stroke for the #1 cylinder to install the distributor.
  5. The good thing, TDC Comp #4 is TDC Exhaust #1
  6. Roll the crankshaft 360 degrees and you will be at TDC Comp #1.
Old Apr 27, 2022 | 06:47 PM
Thanks for the useful post!
What did you have available in terms of a manual? Haynes? A GM manual?
Old Apr 27, 2022 | 07:49 PM
mojave.joe's Avatar
Haynes, but it sucks.
mojave.joe
Apr 14, 2022 07:57 PM
mojave.joe
Apr 12, 2022 09:15 PM
mojave.joe
Apr 11, 2022 04:42 PM
Corey Mondragon
Apr 13, 2014 10:21 PM
ChevOeat
Oct 13, 2012 10:56 AM
