1999 Blazer engine knock
Old Mar 14, 2013 | 04:44 PM
Trevor Miller's Avatar
Trevor Miller is on a distinguished road
Default 1999 Blazer engine knock
Have an engine knock in a 1999 Chevy Blazer 4.3L Vortec Engine. Knocking on the inside of the engine on the left side towards the front near the alternator. Thought it was a stuck lifter but a motor flush and oil change didn't fix the issue. When it started the knocking in the engine, noticed the oil gauge would drop to 20 while driving and then to 0 when coming to a stop and back up again when accelerating. Stopped driving it once it started. Thinking that a rod is the issue.
Is it possible to replace just rods or other parts without having to replace the entire engine? Or what other possible issues could it be?
Old Mar 14, 2013 | 10:02 PM
bryanbc's Avatar
bryanbc is on a distinguished road
You might have spun some bearings. Thats what happened to mine, my oil pressure would be at 0 at a stop and go up to 20 when moving and when you rev the engine you can here a knock so i pulled my engine and tore it down and the crankshaft was shot with the bearings
Old Mar 14, 2013 | 11:52 PM
97cherryblazer's Avatar
97cherryblazer has a spectacular aura about97cherryblazer has a spectacular aura about
Depending on how bad it is you may be fine with just replacing the bearings and having the crank made circular again. if the crank is beyond repair then youre better off looking for a used low mileage engine.
Old Mar 15, 2013 | 01:32 AM
bryanbc's Avatar
I bought a reman crank from autozone for 188
Old Mar 15, 2013 | 03:27 AM
1sttimejimmyowner's Avatar
1sttimejimmyowner is on a distinguished road
If its tht bad off you can look forward to changing or tearing apart your engineto fix it.The crank is probaly toast along with the bearings
fredguaz
Dec 11, 2017 08:11 AM
muskyhunter1212
Sep 1, 2013 10:51 AM
ejschultz
May 23, 2009 04:15 PM
natebluecat
Jan 2, 2009 03:09 PM
