1999 Blazer Timing Chain Replacement Woes...
Old Apr 14, 2022 | 10:36 PM
mojave.joe's Avatar
mojave.joe is on a distinguished road
Default 1999 Blazer Timing Chain Replacement Woes...
Hey Guys,
I am trying changing out the timing chain on my 1999 Blazer, 4x4, Auto, 169k miles.
I begin this odyssey trying to solve a P1345 error. I replaced the cam timing sensor, to no avail then I checked the timing chain and discovered too much play. Now I am assembling the replacement chain and sprockets and I am having issues.
I rotated the camshaft until the mark aligned with the balance shaft mark.
I put the camshaft sprocket in place, just like in illustrations, and the timing mark points to 6pm, or the crankshaft sprocket mark.
So far everything looks good, but when I align the harmonic balancer… the two timing marks are off, like way off.
The harmonic balancer is off, by nearly 180 degrees….
How have I screwed this up?
How can I be at TDC for #1 or #4 ?
Should both timing marks, the camshaft sprocket and crankshaft sprocket, be pointed down at at 6pm?
The camshaft dot has been moved, and is at high noon.
mojave.joe
Apr 14, 2022 07:57 PM
Navalned
Aug 15, 2021 03:12 AM
pimpin
Aug 13, 2021 11:32 AM
Eluv123
Dec 22, 2019 04:00 PM
ComputerNerdBD
May 22, 2016 07:29 AM
