1999 Blazer Transmission upshift issues after driving for a half hour
Old Nov 7, 2016 | 04:29 PM
Robertwmagee's Avatar
Robertwmagee is on a distinguished road
Default 1999 Blazer Transmission upshift issues after driving for a half hour
Hoping that with all of the knowledgable folks in this forum I can resolve this issue.
I have a 1999 Blazer 4.3 Automatic Trans. It was running fine and I have done a lot to it including trans fluid and filter. It developed a crack in the radiator tank so I replaced the radiator with a new one, after about a half hour of driving I noticed a issue with upshifting from a dead stop. It will shift if I wind it out to 2500 rpm and let up of the gas. Changed the Throttle Pos Sensor and harness. Still after driving about a half hour it has a problem with the upshift from a dead stop. It upshifts fine if I do it manually and there are no other shifting issues. When it is cold it shifts just fine.
The fluid smells fine and it is circulating through the radiator cooler.
I would greatly appreciate any help or suggestions I can get.
Old Nov 11, 2016 | 06:08 PM
Nyshadow's Avatar
Nyshadow is on a distinguished road
Mine is doing something Similar. From what I've been reading possibly the shift solenoids. I'm going to try and replace those and see how it goes.
Old Nov 20, 2016 | 07:04 PM
let me know what you find out. so far i have traced all wires going to transmission and transfer case also replaced speed sensors and changed complete valve bodys from a transmission that worked fine. I seriously have no clue why it is doing this. I have owned this blazer since 2012 and have only put about 400 miles on it.
matt4x4
Jan 11, 2015 07:36 AM
sjmcarz
23
Mar 18, 2012 03:34 PM
ddog800
14
Feb 16, 2011 03:01 PM
TheNasty0ne
Dec 17, 2010 09:59 PM
jjimmy
Nov 8, 2007 04:43 PM
