1999 Chevy Blazer 4.3L build questions
Old Jan 20, 2013 | 08:02 PM
bryanbc's Avatar
bryanbc is on a distinguished road
Default 1999 Chevy Blazer 4.3L build questions
im wanting to upgrade my cam(Lunati 262) and valve springs(350 springs). iv heard that i have auto timing but i have never heard of this . so my question is if i change my cam valve springs and lifters. i will have the internals of the motor completely balanced . heads shaved cylinders bored. this being said will i run into any issue with timing or any other type of computer issues?
Old Mar 28, 2019 | 01:19 PM
Frank Bukowski's Avatar
Frank Bukowski is on a distinguished road
Not familiar with the camshaft you choose , however when choosing a cam there are certain parameters that need considering , like what rpm band the cam works well in , will you be able to operate in the band with your rear end gearing & what rpms does the highest vacuum levels operating . Some cam cards will give instructions on what engine timing is best . Do you have a auto trans , or a manual trans ? The auto trans can be less forgiving without changing the torque converter
Old Mar 28, 2019 | 04:50 PM
following
Old Mar 28, 2019 | 05:42 PM
cleburne red's Avatar
In the last six years, I bet OP has either done the cam, or given up on it...
Old Mar 28, 2019 | 07:15 PM
Oh man... was following... but not commenting... oh boy lol
man0steel
Engine & Internal
Apr 28, 2019 12:59 PM
mikeyblazerss
Sep 7, 2011 12:10 PM
brooklynRick
Performance & Brainstorming
Apr 8, 2011 05:09 PM
R2P
Engine & Internal
Nov 8, 2010 04:25 PM
95blazer4wd
Sep 18, 2008 10:38 PM
