2.8 to 3.4
Not knowing your year...
Anyway, yes, the 3.4L is a common replacement for the 2.8L and I believe it is a direct drop in. There may be some modification to the wiring to extend connectors to the appropriate locations, but the mechanicals should work without a hitch.
This should help explain it a little more.
http://www.s10extremist.org/tech_art...28to34swap.htm
Basically the 3.4L V6 is a 2putt8 that is bored out for 20% gain in power.
