2.8 to 3.4
Old Dec 24, 2007 | 08:53 PM
mr_jits's Avatar
mr_jits is an unknown quantity at this point
Default 2.8 to 3.4
Is the 3.4 a possible direct replacement for the 2.8? I need to either rebuild my little 2.8 or replace it and don't want the trouble of a V8 conversion.
Old Dec 25, 2007 | 12:17 AM
Default RE: 2.8 to 3.4
Not knowing your year...
Anyway, yes, the 3.4L is a common replacement for the 2.8L and I believe it is a direct drop in. There may be some modification to the wiring to extend connectors to the appropriate locations, but the mechanicals should work without a hitch.
Old Dec 26, 2007 | 03:15 AM
Hanr3's Avatar
This should help explain it a little more.
http://www.s10extremist.org/tech_art...28to34swap.htm
Basically the 3.4L V6 is a 2putt8 that is bored out for 20% gain in power.
