2.8 V6 carb problems
Old Nov 15, 2008 | 09:41 PM
wyk's Avatar
wyk
wyk is an unknown quantity at this point
Default 2.8 V6 carb problems
I just came into a 1985 blazer and the carb is flooding pretty badly when I get on it. The mech, a friend of mine, says it isn't turning the choke off right far as he can tell. What options do I have in repairing it? When the engine is warm oftentimes it will not start. It will flood. I have to basically hold open the butterfly and gun it and hit the starter for a while to get it to start again due to the flooding. Next year I do not have to have smog, so an aftermarket intake and carb that will work with whatever OEM stuff is hanging off the engine right now is an option.
Obliged,
Wes
Old Nov 15, 2008 | 10:21 PM
in4lo's Avatar
in4lo is an unknown quantity at this point
Default RE: 2.8 V6 carb problems
You could take the choke off completely and pump the hell out of it to start it cold as a temp fix. If thats not an option, check Jegs and Summit for carbs that will fit. I know nothing of the 2.8s, I have a 2.8 multiport in a Pontiac, but never even SEEN a carbed version...
Old Nov 18, 2008 | 10:47 AM
wyk's Avatar
wyk
Can I get a standard non-electric varajet to work in this set up? I see those for sale for cheap. I dont need to pass smog with this year blazer.
Old Nov 18, 2008 | 05:12 PM
in4lo's Avatar
I know there's a 4bbl intake floating around (aftermarket) on the net somewhere for the 60 degree v6es. I don't know if the non electric will fit, as again, I know zilch of these engines. I just know enough about carbs in general that removing the choke will murder that problem, but it'll make it a PITA to start when it's cold (getting down in the teens F tonight here... good time to test the cold starting ability on my '00 I've had since early Oct.)
Old Nov 26, 2008 | 01:40 AM
wyk's Avatar
wyk
Hey guys, here's the update:
I got a rebuilt carb off a 1983 Buick. It works - good. It has no mechanical kick-down - bad. But the vacuum or whatever helps it kick down in all but overdrive. I had to reroute some vacuum hoses, as some were on opposite sides of the carb. Now it runs fine. Well, as fine as a 2.8 is gonna run. Still gutless... My mpg has gone up a lot, though.
WYK
Brandon Smith
Dec 22, 2013 12:33 PM
BVFD25
Oct 7, 2012 10:42 PM
Manley_pm
Dec 19, 2005 11:18 PM
jotajota
Engine & Internal
Dec 11, 2005 11:45 AM
zero psi
Engine & Internal
Dec 11, 2005 12:20 AM
