2 broken blazers to make 1 (opinions please)
Old Jun 8, 2012 | 03:51 PM
xillzxnickx's Avatar
xillzxnickx is an unknown quantity at this point
Default 2 broken blazers to make 1 (opinions please)
ok im going to start with a story before getting to my real question so you know the history lolo
i started off with a 1995 blue 4dr blazer with a carb set up not tbi yes carb a quadrajet. i got stuck in a mud hole and spun two main bearings
so i took a short block from my auto teacher and everything went good but we had to make a custom oil pick up beacuse i guess i got the worng oil pan and it was too shallow
everything went good and when we went to start it it blow a rear main seal so i fixxed that and still blow it so after a total of 3 seals and trying to find the cause i gave up
i bought a new balzer 1997 black 2dr 5 speed blazer and started building this one up
Old Jun 8, 2012 | 03:54 PM
so my question is for the black one should i keep the engine in it now it has 119k and redo the rotating assembly with the engine from the blue one or take the blue ones engine and find why its building to much pressure and blowing the rear main seal or just start from a whole new short or long block l
moneys really tight i do have all the gaskets to do a rebuild tho new mounts etc
Old Jun 8, 2012 | 04:07 PM
frogot this part ... had to type it twice because of crap o internet
the black one
driving on the highway my car stalled and i restarted it and had a hello loud rod knock and 10 mins before that i was fooling around with a friend and did 5th to 3rd drop but rev matched
but dont get how i broke the rod after like 10min after
Old Jun 8, 2012 | 04:54 PM
raven71's Avatar
raven71 is an unknown quantity at this point
I would do the black one and sell me the blue one cause I have a engine to put in it. from a 96 that was just wrecked. I hope your on Long Island or near me...In matter of fact you look rich enough to just give me the blue one. Now let me give you an idea why you kept blowing the rear main. Check the oil pump relief valve. and plastiguage the crank bearings to see what clearance you have. also check the crank where the seal rides for any sharp protruding pieces or even small depressions. I'm giving you the benefit of doubt you are putting the rear main seal in the right way.
If you do decide to fix it put a oil pressure gage on it to check oil pressure when you get it running. To blow 3 rear seals something is not being put together right, something is ripping the seal or something is causing excessive pressure.
The only times I have run into this is with pressure relief valves not working , or when I would build dry sump systems for engines. In my time it has only been 3 engines I had that happen on. one was the mechanic who did it kept messing the wick seal. The others were a machine shop error.
By the way that is a sweet looking black Blazer. Really fix it up and keep the engine in it
Old Jun 8, 2012 | 10:11 PM
yes i am on long island exit 67 on lie the truck doesnt look like that anymore tho it on jackstand and tranny is dropped and the leather seats are in the black one ...
but if you are really interested in it let me know because iw as going to gershow it
Old Jun 8, 2012 | 10:13 PM
ive doone everything youve said but the oil pump relief valve
just it not even 3 seconds on crack before the seal blows the lip on the seal inverts
Old Jun 8, 2012 | 10:22 PM
so what your telling me is to basicly rebuild the black trucks engine right
should i use the engine from the blue one ? because i dont have money for other crap im not rich lmao
Old Jun 9, 2012 | 06:31 AM
raven71's Avatar
I'm interested to look at anything I go out to Calverton to shoot so I know were you are. Pm or send me a number to call our I will send you mine. I'm headed to Great neck soon for a MRI of my back, but I will get in touch with you. How much of a lift and did it have a 4.3 to start with.
Mauve I can look at the engine for you that the seal Jeeps blowing on and give you an idea what it can be.
Old Jun 9, 2012 | 06:36 AM
raven71's Avatar
In matter of fact if your interested I have a 96 that I was going to part out. The tires are Yokahamas 3 Weeks old. And I did work to my engine and Trans a while back. The front was hit and I have a bent frame. That's why I say I have a engine and Trans to throw in the blue one
The thing is yours its OBD1 mine is OBDII. Though I can pull the harness and computer to pit in the blue one. My seats are like new but cloth.
Old Jun 9, 2012 | 06:37 AM
raven71's Avatar
Sorry double post don't see how to remove it
