2000 Backfiring thru intake
Old May 3, 2008 | 10:25 AM
johncagain's Avatar
johncagain is an unknown quantity at this point
Default 2000 Backfiring thru intake
Hey guys I bought a 2000 Blazer 2 dr. 4x44.3 autoa couple of mos ago and its got me stumped. It starts and runs fine unless i give it more than 1/3 throttle, then it sputters and or backfires thru the intake and loses power. This will happen on side roads or on the freeway. I have replaced the fuel filter, plugs, wires, coil, dist cap, rotor and cleaned the MAF. Any other ideas? Fuel pump? Thanks.
Old May 3, 2008 | 11:08 AM
2002XTREME's Avatar
2002XTREME is an unknown quantity at this point
Default RE: 2000 Backfiring thru intake
from having an elcamino with a 454 in it and having it pop thru the carb, it turned out the cam is shot on 2 cylinders the lobes are round instead of eggshaped,,,, So in turn theres backfiring thru the carb and the exhaust... How many miles are on it? What # owner of the veh are you and do you know any of the background of the truck? The truck might have been beatin and abused and thats why it was sold in the first place..
Old May 3, 2008 | 11:11 AM
johncagain's Avatar
The woman i bought it off of bought it new (yuppie type) so i dont think she ran it hard. 98k mi.
Old May 3, 2008 | 11:15 AM
2002XTREME's Avatar
what kind of gas are you using and have you put in any kind of injector cleaner?? I use Marvel mystery oil in my blazer havent had any probs yet.. I add it to the gas each fill up..
Old May 4, 2008 | 05:28 AM
johncagain's Avatar
Just 87 regular, various brands. I do add injector cleaner at every oil change.
Old May 11, 2008 | 02:33 PM
johncagain's Avatar
I GOT IT! Thanks to garry2000blazerin the DIY-HOW TOforum, I disassembled it all the way, cleaned it correctly, and it runs like new. Thanks again guys!
Old May 11, 2008 | 06:57 PM
2002XTREME's Avatar
disassembled what item???
Old May 11, 2008 | 07:01 PM
Probably the EGR valve.
Old May 11, 2008 | 08:30 PM
johncagain's Avatar
Sorry ya'all, I ment the MAF as seen on garry2000blazerpost in DIY- How to, it worked out perfectly for me. The truck runs great!
comandoed
Mar 13, 2013 06:56 AM
das96blazer
31
Apr 20, 2012 10:07 PM
biohazrebirth
Mar 24, 2010 07:29 PM
jcortes63
Nov 3, 2008 11:10 PM
Trooper_TK421
Sep 26, 2008 02:50 PM
