2000 blazer 4wd 4.3l problem after intake gasket replacement
Old Oct 21, 2012 | 08:38 AM
yoccrob1's Avatar
yoccrob1 is on a distinguished road
Default timing problem
I have a 1997 blazer 4.3 i replaced the intakes because it was leaking water I forgot to mark the distrubuter when i pulled the shaft well i just put it back in and tried to start it no go. i then redid ever thing to TDC now the engine cranks but seems like something is wrong when it cranks sounds like there its off not a smooth crank is it possible that the timing chain messd up or went off time pleas help
Old Oct 21, 2012 | 12:25 PM
To avoid confussion, it's best to start a new thread. Copy & paste what you have here, that's fine.
Old Oct 22, 2012 | 02:19 PM
ewarma's Avatar
ewarma is on a distinguished road
how did you set the timing? i have a 2000 blazer and the distributor must be put in correctly or it will not run.
here is a link with a diagram for timing. hope this helps
https://blazerforum.com/forum/tech-a...-timing-24373/
Old Sep 3, 2014 | 10:37 PM
Anthony71688's Avatar
Anthony71688 is on a distinguished road
Default Ummmm
I think that is the iat sensor that's what it looks like to me
billfrank85
Apr 17, 2012 08:25 PM
dunontme
Nov 17, 2009 11:04 PM
ComputerNerdBD
Mar 10, 2009 09:33 AM
Exodus5
15
Feb 20, 2008 10:02 PM
brinriha
19
Apr 14, 2007 05:12 AM
