2000 blazer 4x4 4.3L V6 just replaced radiator now oil leak and loss of power
Old Jun 30, 2019 | 01:55 PM
Bgordon987's Avatar
Bgordon987 is on a distinguished road
Default 2000 blazer 4x4 4.3L V6 just replaced radiator now oil leak and loss of power
I just replaced my radiator and everything was fine until I drove it a few miles and now I’m having an oil leak. I checked all of my connections and they are all tightened. It’s a pretty good leak and didn’t start until after the radiator was replaced. Any help would be greatly appreciated.
Old Jun 30, 2019 | 02:02 PM
Where is it leaking from? The oil cooler connections in the radiator?
Old Jun 30, 2019 | 02:20 PM
Bgordon987's Avatar
Default Well
Well i can’t really tell I can just see that it is leaking from almost the very front of the truck. It only started after I put the radiator in
Old Jun 30, 2019 | 02:22 PM
Sounds like maybe the o-rings in the connections are missing or damaged. I don't believe the original radiator uses any o-rings (or at least any that can fall out), but some aftermarket ones do.
Old Jun 30, 2019 | 02:25 PM
Bgordon987's Avatar
So what should I do? What would be the fastest way? I’m not using any power or air tools so it’s been a slow process
Old Jun 30, 2019 | 02:43 PM
First, determine for sure where it's leaking from. You'll probably need a flashlight, and you may need to remove a couple of things to see (possibly the airbox or the fan shroud). Then, disconnect the line where it's leaking and figure out why (assuming it's leaking from one of the cooler lines.
Personally, I removed my oil filter adapter and bypassed the external cooler so I wouldn't have to worry about this kind of stuff.
Old Jun 30, 2019 | 07:00 PM
Bgordon987's Avatar
Default Soooo
Alright so I replaced the o-rings on the connections and now i still have loss of engine power it’s acting as if it’s in a higher gear at start
Old Jun 30, 2019 | 07:02 PM
Did you check the transmission fluid? How much did you lose when you replaced the radiator?
Old Jun 30, 2019 | 08:16 PM
Bgordon987's Avatar
I should probably check. Didn’t even think about it. I also just noticed the top line for transmission fluid is leaking a little. Should probably check on that as well
Old Jun 30, 2019 | 08:17 PM
Bgordon987's Avatar
I really appreciate all your help Tom A. You are the man
