2000 blazer 4x4 4.3L V6 just replaced radiator now oil leak and loss of power
I just replaced my radiator and everything was fine until I drove it a few miles and now I’m having an oil leak. I checked all of my connections and they are all tightened. It’s a pretty good leak and didn’t start until after the radiator was replaced. Any help would be greatly appreciated.
Sounds like maybe the o-rings in the connections are missing or damaged. I don't believe the original radiator uses any o-rings (or at least any that can fall out), but some aftermarket ones do.
So what should I do? What would be the fastest way? I’m not using any power or air tools so it’s been a slow process
Personally, I removed my oil filter adapter and bypassed the external cooler so I wouldn't have to worry about this kind of stuff.
