2000 blazer hesitation and poor Acelleration
Old Aug 22, 2014 | 12:08 AM
00loweredblazer's Avatar
00loweredblazer is on a distinguished road
Default 2000 blazer hesitation and poor Acelleration
i have a 2000 blazer i bought a month ago. now is having a hestation under heavy acceleration. took it to one shop. told me the trans was slipping into 2nd.
proceeded to another shop and they told me the trans was fine and it was the engines performance causing a hesitation and making it sloppy.
bought it and was told it had new
crank sensor
cap and rotor
plugs
wires
fuel filter
trans fluid
trans filter
shift sensor
CEL is on from cat being deleted.
also has a code for the crank sensor. cleared the code at oreillys and still comes back.
2nd trans shop said i should take it in to someone who does engine work.
ive read some people have problems with the MAF sensor causing this.
bad fuel
crank sensor
or the plugs wires etc.
checked fuel pressure and it was in the normal range. 55-60 with key on.
sometimes it wont start. and i have unplugged crank sensor and plugged it back in and it usually fires right up.
any help. dont want to keep throwing money into it on sensors that wont help!
thanks!
-Alec
Old Aug 22, 2014 | 10:27 AM
sporty982000's Avatar
sporty982000 is on a distinguished road
You tried seafoam ? Clean injectors ? You can also add to oil. Can help clean stuff too
Worth a try.
Seafoam has helped me with simuliar issue.
Old Aug 22, 2014 | 12:09 PM
er0ck273's Avatar
er0ck273 is on a distinguished road
when you replaced the crank sensor, did you disconnect the battery and put it on AFTER you put the crank sensor on? if im not mistaken, it will not relearn and cause problems. i was also told it had to be relearned using a GM tech 2 which isnt cheap and usually on GM has them
Old Aug 22, 2014 | 08:06 PM
I did not do the crank sensor. It was done previous to me purchasing it.
It's currently in the shop. Got the rear diff pinion bearings replaced.
It wouldn't start. So I had to have it towed to another shop to get worked on and figure out the no start now. Hopefully he can figure out what's wrong. It's outta my hands now :/
Old Aug 22, 2014 | 08:40 PM
07nhbpsi's Avatar
07nhbpsi is on a distinguished road
I hope for your sake it's not at sumpter auto!!:icon_
notjustsomeone
Jun 23, 2013 10:50 PM
BlackMatter
Feb 16, 2012 10:27 PM
pappyam
Dec 19, 2010 08:08 AM
fernandoh
Apr 12, 2007 12:19 AM
gibbylt1
Jul 31, 2006 01:27 PM
