2000 blazer stalls when given gas at a stop.
Old Mar 8, 2019 | 02:03 PM
Krushin's Avatar
Krushin is on a distinguished road
Ok so as an update: fuel pressure is good. I put the motor at top dead center on 1, and I looked at the distributor. It was not lining up with the 6. So I pulled the distributor and moved it back a tooth and it was where it needed to be. Now to get the distributor to drop down on the oil pump arm I turned the crank clockwise till it dropped down flush. I put it all back together except I forgot to plug the distributor back up. I started it and it ran great! The tachometer did not read anything and I remembered I forgot to plug it back in. I turned it off and plugged it back in and it started right back up. I am getting a 1345 code for crankshaft and camshaft correlation. It runs great with no more stuttering and dying but I would like to address this new problem. Thanks in advance.
DenaN
Aug 7, 2018 12:24 PM
Hhardy
Sep 3, 2017 01:52 PM
blazin734
Jan 9, 2012 03:44 PM
Nbkornmann@yahoo.com
Jan 27, 2011 06:18 AM
Lyon
Jul 23, 2009 07:09 AM
