Engine too cold, engine check light on
Old Mar 2, 2019 | 10:42 PM
StijnV's Avatar
StijnV is on a distinguished road
Default Engine too cold, engine check light on
Hello,
I have been looking through some other threads but haven't been able to find a solution for my problem which is the following.
Yesterday I got an engine check light. My car is a Chevy Blazer 2001 4.3L LS Right hand drive.
For the past few days I have noticed my engine doesn't heat up until 90 degrees Celsius (based in New Zealand). It only goes up till about 60-70 degrees Celsius.
I have replaced the thermostat as I thought this might be the problem. I did test the old one and seemed to be fine but still have replaced it.
This actually didn't make a difference. Would anybody have an idea where to look to find the problem? I'm currently also looking into buying into a good OBD2 bluetooth tool so don't have the codes yet.
At the same time my HVAC motor is also broken. The wee pin that connects to a vacuum actuator broke off so I don't have hot air in my car at the moment. Could this be related to my engine not getting hot enough?
Thanks in advance.
Old Mar 4, 2019 | 11:26 AM
go chevy's Avatar
How long has it been since you did a radiator flush and fill? Might be as simple as that??? Just a guess on my end though
Old Mar 4, 2019 | 05:28 PM
StijnV's Avatar
I have completely flushed both radiator and heater core about 2 months ago so that would be an odd thing. It all happen at a sudden about a week ago. First few days no engine light but cold motor and then the check engine light. It runs and drives with no issue but don’t want to have any more damage
Old Mar 4, 2019 | 06:06 PM
odat's Avatar
Check your clutch fan, make sure it's not locked and spinning solid all the time - My Dodge Cummins was running cold - thermostat, water pump ECT all checked out good but the clutch fan was bad, no free wheel at all
Old Mar 4, 2019 | 08:10 PM
StijnV's Avatar
You could be right! If I try to turn my fan when engine is off it only goes for about 1/4 turn. When I accelerate when cold it is really loud, it looks like it isn’t disengaging at all. How can I properly determine if my fan is bad? Thanks for your help!
Old Mar 4, 2019 | 09:20 PM
odat's Avatar
Engine off it will be stiff but you will be able to spin it all the way around. They make a loud whooshing noise at the start of acceleration esp. when engine is cold. If noise is continuous all the time and if won't spin I'd say it's shot.
Old Mar 7, 2019 | 02:36 PM
LesMyer's Avatar
Temp sending unit could be faulty. SES light could be on for the lower than expected temp the PCM is seeing. You did put a 195°F thermostat in it, correct? If only 60°-70°C, you should be able to hold the top radiator hose in your hand without burning.
Old Mar 8, 2019 | 04:42 PM
StijnV's Avatar
The upper hose is too hot too touch at the moment. I still don’t get the heat it supposed to give. I read the codes and it’s giving me a P0128 which is coolant thermostat. However, I replaced the thermostat so not sure why I’m getting that. The engine light did come off but still don’t get heat. I had a look at my HVAC motor, I see all the actuators moving but I did discover that a little piece of the motor broke off. See pictures. This probably needs to be attached? I’m not sure if these problems can relate.
kevinph
Aug 13, 2012 05:49 AM
Blake726
Aug 4, 2012 05:37 PM
deedosmith
Sep 15, 2010 09:18 PM
djdrew010
Apr 21, 2009 02:37 PM
Trisa
Apr 19, 2007 10:59 PM
