2000 Blazer staritng problem.
Old Mar 28, 2010 | 06:38 PM
Originally Posted by swartlkk
It should not drop more than 5psi. You have a leak somewhere in the system. You can purchase adapters to mate the pressure tester to the line on the tank side of the fuel filter to see if the leak is in the tank or in the engine.
^^^^ Did you miss that? ^^^^
It is possible that the FPR is at fault, but I would want to remove the fuel lines on top of the engine, pull the upper plenum, reinstall the fuel lines, and then pressurize the system to be sure. But before that, check to make sure that it isn't a problem with the fuel pump as I pointed out earlier.
Old Mar 28, 2010 | 06:40 PM
rcillig's Avatar
rcillig is an unknown quantity at this point
Yes I did to be honest, ok they will have that as the local auto shop I take it ?
Old Mar 28, 2010 | 07:11 PM
Have what at the local shop? The necessary adapters (doubtful) or the necessary equipment to test the coil (also doubtful).
The later part of the fuel pressure test instructions I posted earlier has the 10psi pressure drop test which should identify a leaking check valve.
Old Mar 30, 2010 | 01:39 PM
rcillig's Avatar
ok I cant seem to locate a fitting to attach the fuel gauge to the fuel filter end of the fuel line, any idea where I may end up finding something like that?
jello219
Sep 3, 2019 05:19 PM
01Blaze218
Oct 13, 2011 10:05 AM
laff31
Dec 30, 2009 04:55 PM
stingra65
Jul 25, 2007 07:52 PM
rellima1
May 18, 2007 11:20 AM
