2000 jimmy tccm
Old Oct 6, 2015 | 02:14 PM
Vacuum reservoir. Check your local boneyard.
Old Oct 7, 2015 | 11:47 AM
LesMyer's Avatar
Originally Posted by yomamas
also when i was checking the hoses i broke the stem on the vacuum reservoir/amplifier that is hidden In the driver side fender that goes over to the solenoid hook up .what is it and what would be the easiest way to fix this?
thanks for all the help
Remove it and epoxy! Don't try it in place.
Old Oct 7, 2015 | 11:54 AM
LesMyer's Avatar
i tried to turn it but it wouldnt move in either direction. does that mean its stuck or froze up or something?
If you can't move it with a wrench with trans in neutral and all 4 wheels off the ground, then yes.
Old Oct 7, 2015 | 06:04 PM
yomamas's Avatar
yomamas is on a distinguished road
ok i got it to shift out of gear but not sure on the direction to turn.. look like it was all the way to the right was 4 high then going to the left was neutral the 4lo not sure where 2 hi is on the trnsfer .is it to the right or left past 4 hi or past 4 low/ any help please
Old Oct 7, 2015 | 06:26 PM
I believe that the 236 is similar in shift positions as the 231/233/243 transfer cases with the possible exception of the angle between 2HI and 4HI to give some variable lockup of the front prop shaft clutch for the Auto4WD mode.
Here is an illustration from RSGear.com on the 243 transfer case:
Old Oct 7, 2015 | 06:54 PM
yomamas's Avatar
ok it seems like its backwards from that picture . as im looking at the shaft 4 lo is at the bottom then neutral then 4 hi going right or clockwise, then it seems like it just springs right a little more then back not shifting to 2 hi. thanks for all the help so far guys this jimmy is a present for my daughter and i just want her to be safe this winter .
rednekk
Dec 12, 2011 02:30 PM
Tinted
Nov 29, 2011 02:06 PM
dazanez
Nov 17, 2011 04:30 PM
tjmicsak
Nov 28, 2010 08:19 PM
millernet
Oct 14, 2010 03:09 PM
