2000 l.s. stuck in 4 high
Old Apr 15, 2011 | 10:26 PM
ososbill's Avatar
ososbill is on a distinguished road
Default 2000 l.s. stuck in 4 high
Transfer case will not release from 4 high, no major use if 4 wheel drive ever. I am thinking the engagement solenoid is dead or dirty. I am certain this is not a major issue. I encountered this in Colorado with snow and ice and after cleaning and re-intalling the accutator all worked well. Any input will be gratefull. ososbill
Old Apr 16, 2011 | 08:15 AM
The last vehicle that I worked on with this condition, the problem turned out to be a failed gear inside the encoder motor.
How many buttons are there on the transfer case switch in the dash.
Old Apr 16, 2011 | 09:36 PM
ososbill's Avatar
Thanks for the respond, there are two buttons on the dash, high range, and low range. Any other input? ososbill
Old Apr 17, 2011 | 06:35 AM
Can you post a picture of your dash switch... The options for 2000 were the 3-button (2HI, 4HI, & 4LO) and 4-button (Auto4, 2HI, 4HI, & 4LO).
If you do not have the 4-button switch, you have the NV233 transfer case. There is a LOT of information here about the NV233 and how to trouble shoot it. Check the Tech Article (DIY) section.
stingray74
Mar 5, 2015 08:27 PM
mr.vls
May 4, 2013 03:45 AM
Havensk
Jul 25, 2010 08:16 PM
dcblazer
Dec 18, 2006 06:07 AM
1998 blazer
Jul 8, 2005 11:05 AM
