2000 ZR2 Blazer Help
Old Jul 9, 2015 | 10:54 AM
xVENOMx's Avatar
xVENOMx is on a distinguished road
Default 2000 ZR2 Blazer Help
My 2000 Blazer was running fine until the starter went out on me one day. So I replaced it ( in the grocery store parking lot) and she started right back up and drive home no problem. The next day I drove it to work fine however, when I started home it started bogging down like it was about to run out of gas. If I press the clutch in and rev the engine I can get her going again. Luckily made it home. It will start and idle no problem but now as soon as I drive 10 feet it wants to die on me. I did replace the fuel pump a couple of months ago so pretty sure that's not it. I am thinking maybe the fuel filter? Any help is greatly appreciated thanks in advance.
Old Jul 9, 2015 | 11:20 AM
Check fuel pressure and leakdown. This thread explains: https://blazerforum.com/forum/2nd-gen-s-series-1995-2005-tech-41/how-check-regulated-fuel-pressure-pump-max-output-leakdown-88305/ Post all 4 readings and We can help you analyze them.
Old Sep 5, 2022 | 12:29 AM
ethanturner's Avatar
ethanturner is on a distinguished road
I know the pressure at the rail is good. I forgot to mention the starter doesn’t even turn when it dies.
Old Sep 5, 2022 | 03:49 PM
GeorgeLG's Avatar
If you have a problem and are looking for help, start a new thread, state your symptoms and explain what you need.
George
my96blazerneedshelp
Apr 6, 2013 07:41 PM
filtalr
Jul 25, 2011 09:23 PM
infyre
Jul 31, 2010 07:40 PM
mrshaneb
31
Jul 3, 2010 01:16 PM
raymondabryan
Jan 7, 2010 07:15 PM
