2001 4X4 Blazer Not Starting
Old Dec 28, 2010 | 12:40 PM
JustJerry's Avatar
JustJerry is on a distinguished road
My opinion of buying a use fuel pump is NO. Its liable to be bad, and there is much effort that goes into changing a fuel pump.
Old Dec 29, 2010 | 07:04 AM
Mgregory2K's Avatar
Mgregory2K is on a distinguished road
Yeah, I was just hoping someone could validate my laziness. I'm going to work on it this weekend and do it right. I've burnt myself in the past by half-azzing jobs.
Thanks for all the help and if I run in to anymore issues I will probably be back.
Old Dec 29, 2010 | 01:24 PM
JustJerry's Avatar
I would not buy a used one. Its way to much work to go through just to put a used one in.
Even though the used one was working when the vehicle was wrecked or junked out, after setting for a long time it may not work, and even if it does it may not last very long.
Old Dec 29, 2010 | 10:34 PM
blazinloud's Avatar
i was talking with a co-worker about when i changed my pump and the fact it was so expensive. He's a good shade tree/redneck mechanic that builds big mud trucks/engine swaps and such and asked why i didnt just use one out of an old camaro......? will they actually work?
Old Dec 30, 2010 | 07:00 AM
Mgregory2K's Avatar
So, I can get the Blazer started with carb cleaner in the intake, but it won't stay running. Even if I hold the gas down it stalls out.
Is that still fuel pump or fuel injector...or both?
Old Dec 30, 2010 | 07:05 AM
That verifies that it is a lack of fuel causing the no-start condition. A fuel pressure and leak down rate test is necessary to determine the true cause.
Old Jan 2, 2011 | 04:01 PM
r6thor's Avatar
r6thor is on a distinguished road
my 2000 zr2 is having a starting problem as well only when i use starting fluid is does nothing i have changed out the dist cap and rotor. any ideas
Old Jan 2, 2011 | 04:03 PM
No problem in following along in a thread, but when it comes to asking for help with a question that has different conditions that of the OPs problem, it is time to create a thread of your own.
Old Jan 2, 2011 | 04:20 PM
r6thor's Avatar
ok sorry
Old Jan 3, 2011 | 07:09 AM
Mgregory2K's Avatar
This thread is OK to close by me. However, I've run out of things I can do on my own so I'm dropping it off at the shop at the end of the week. If you'd like to keep the thread open I can post the final fix (according to a auto shop)
