2001 blazer 4x4 won't engage
Old Dec 15, 2016 | 06:04 PM
Mike McGhee's Avatar
Mike McGhee is on a distinguished road
Default 2001 blazer 4x4 won't engage
Hey guys, I know this is kind of a common issue, so I hit the 4wheel hi or low I hear the actuator on the transmission try to engage but nothing happens and I only get blinking lights. Any help would be great.
Old Dec 16, 2016 | 08:49 PM
okaussie's Avatar
okaussie is on a distinguished road
First you have to find out whether it is electrical, mechanical or vacuum
What happens when you put it in 4hi?
What do the lights do, do you hear the encoder motor shift, how does it feel in the steering wheel, what do you hear??
Places to start...
Old Dec 17, 2016 | 09:14 AM
I select 4hi and I here module behind right side kick panel, and motor encoder make a noise, but nothing engages. Light just flashes. I've check the vacuum actuator. When I depress it I here a hissing noise come from the transfer case solenoid on the firewall. I just bought a new transfer case solenoid will be here in a couple days. Hopefully that works.
Old Dec 17, 2016 | 10:15 AM
okaussie's Avatar
First, is it the Three Button or Four Button dash controls?
Second, what is it you hear from the TCCM in the right kick panel??
Third, what is a new transfer case solenoid??
If you have the 4button version, I cannot help you. I have the 3button version with the vacuum actuator under the battery tray.
Bill
Old Dec 17, 2016 | 11:01 AM
4 button. The module just makes a noise like its engaging something and I hear the encoder motor doing something. I do have a vacuum acuator underneath battery tray. No leaks in it.
Old Dec 17, 2016 | 11:53 AM
okaussie's Avatar
Sorry, I can't help you with this one. I have a 2002 S10 CrewCab 4wd with the 3button 4WD. I am only familiar with this one.
I am sure there are others out there with the experience needed to help you ..
Bill
Old Dec 18, 2016 | 12:21 PM
Strangerock's Avatar
Strangerock is on a distinguished road
You can bypass the solenoid on the firewall by hooking the lines direct ....this will tell you if the solenoid is the culprit.
Old Dec 20, 2016 | 06:28 AM
stonecoldsteele's Avatar
stonecoldsteele is on a distinguished road
Does the light flash when you try to engage it into 4WD? I think 5 flashes means it is the encoder motor has gone bad.
Old Jan 10, 2017 | 06:38 PM
Mannclan's Avatar
Mannclan is on a distinguished road
Mine does that occasionally. I put it in neutral and back to park and it locks in.
xjchase
Nov 16, 2014 04:12 PM
xjchase
Nov 15, 2014 08:59 PM
surei
Sep 6, 2010 09:12 PM
jpmccr
Dec 29, 2009 03:20 PM
