2001 blazer locked in 4lo
Old Oct 23, 2011 | 01:07 AM
chevy lady's Avatar
chevy lady is an unknown quantity at this point
Unhappy 2001 blazer locked in 4lo
I put my blazer in 4lo tonight and can not get it to shift back out. I have no lights on the auto buttons, it has auto 4, 2hi, 4hi, 4lo and the service 4wd light came on . Checked the fuse inside and it was good, when I checked the fuse under the hood it was blown, When I tried to replace it . it popped the minute I put it in. Put a jumper wire in and the lights came back on but could not get it shift out of 4lo. Any suggestions would be appreciated you guys have come through for me before. Don't want to have to take it to the dealer. I am in upstate New York and will need my 4wheel working soon.
I have been looking through the forum but am trying to figure out why the fuse keeps blowing
and where to go from here.
Thanks Chevy Lady, not a mechanic ,but not afraid to try.
Let me apologize now if I am not posting this correctly pretty new to this stuff but have found lots of great advise on this sight over time. Thanks Again
Old Oct 23, 2011 | 10:14 AM
chevy lady's Avatar
Can someone tell me what may be causing the fuse to continue to blow?
Old Oct 23, 2011 | 10:21 AM
FsTFwRd's Avatar
Have the lights been burned out on the switch for a while, or is that something new?
Old Oct 23, 2011 | 10:23 AM
mychevyisntheavy's Avatar
mychevyisntheavy is on a distinguished road
ok i just had a about the same problem with mine, u need to check ur encoder motor, if i was u i would just unplug it from the tranfer case. check the plug from the truck, 4 of the wires should have 5 volts. its held on bye a 8 mm bolt. put the fuse back in, if it doesnt blown then its proubly the problem. i would never just put a jumper wire in the fuse box for anything ur gonna ffire something bye doing that,
Old Oct 23, 2011 | 10:39 AM
chevy lady's Avatar
Lights just went out! It was running fine in 2hi but was running through them to check them and it locked in 4lo and no lights and blew the fuse
Old Oct 23, 2011 | 10:59 AM
FsTFwRd's Avatar
Originally Posted by mychevyisntheavy
ok I just had a about the same problem with mine, you need to check your encoder motor, if I were you I would just unplug it from the tranfer case. check the plug from the truck, 4 of the wires should have 5 volts. It's held on by a 8 mm bolt. put the fuse back in, if it doesn't blow then its probably the problem. I would never just put a jumper wire in the fuse box for anything, you're gonna fire something by doing that,
Need to lose that jumper wire as soon as you can, there is a reason for the high current causing the fuse to blow. Having that wire could cause you more problems electrical wise.
Old Oct 23, 2011 | 11:58 AM
chevy lady's Avatar
didn't leave it in there just put it in there to check to see if lights would come back and if we could shift it out of LO
Old Oct 23, 2011 | 07:34 PM
i think ur encoder motor is out
chrisv2069
Jan 6, 2010 04:21 PM
nygneonkurtis
14
Mar 8, 2009 07:35 PM
Alterac
Aug 25, 2008 08:48 PM
michellesmark01
Engine & Internal
Jan 21, 2006 07:30 AM
DaveInDaytona
Jan 6, 2006 11:19 PM
