2001 Blazer Zr2 - usedmotor/crank sensor/misfire=wits end!
Old Jun 7, 2022 | 07:04 AM
shonB's Avatar
shonB is on a distinguished road
Default 2001 Blazer Zr2 - usedmotor/crank sensor/misfire=wits end!
Bought this needing a sunshell.. 300 miles later it spun a main bearing at 110k... cursed... used engine 152k... ran good except for a slight feeling of miss at highway speed, occasional sometimes worse than others.. then it began actinh erratically at higher rpms throwing p0335.. crank sensor erratic, tried another.. multiple crank relearns after each adjustment.. same result.. shimmed, fixed the p0335, but created random misfire, p0300... worst on cyl 4 and 1 trailing it... misfire is worse when warm and most misfires occur the most when high rpm with complete let off of throttle... new plugs wires, complete distributor with cam sensor... cam retard was 7 i set to 0... wires from crank to pcm ohmed out good... please help!!! any ideas..
Old Jun 7, 2022 | 08:55 AM
GeorgeLG's Avatar
Misfires can be a bit of work to solve but you came to the right place. Let’s get you fixed up.
First make sure that your fuel pressure is solid with no leakdown by doing the fuel pressure test in the sticky
If you swap plugs and wires between the misfiring cylinders and good cylinders does the misfire follow?
Do you have any carbon traces under the distr cap?
mist the engine in the dark and look for arching.
do you have a recent compression test?
what is the history on the injectors?
what are your fuel trims?
George
Old Jun 7, 2022 | 09:22 AM
shonB's Avatar
George
i appreciate the help!
ive done so much ill try to remember all ive done and do any suggestions asap and report back
fuel pressure was 55 but didnt check for leakdown
all cylinders misfire randomly but 4 is the most and i will switch that plug and wire when i can if u think i need to.. did the same with old plugs and wires
it has a new distributor and contents a few days ago... the old cap had alot of build up but it was from the original motor
i did look for arcing in the dsrk but ill have to look into what you mean by misting
i feel i did a compression test on this engine a month ago when i first got it in and wasnt concerned but can do another and report
the intake and injectors are from the original engine that ran perfect until that bearing thought it was a brake drum
STs <5 LTs close to 0
Old Jun 7, 2022 | 09:24 AM
shonB's Avatar
One very odd thing i found while check over my work was the 2 black grounds, i think its g117, on the back of the drivers head have 12 volts when unhooked from block! cant be right... lol
Old Jun 10, 2022 | 10:45 AM
LesMyer's Avatar
If you remove a main ground like that it will have voltage on it because something wants it to complete the circuit.
Old Jun 10, 2022 | 10:48 AM
shonB's Avatar
Thank you... dealer just called, plenum gasket, injectors, cap, rotor, and 5 psi op at idle.. its about to get full coverage, lol
Old Jun 10, 2022 | 11:17 AM
shonB's Avatar
Old Jun 11, 2022 | 10:49 AM
shonB's Avatar
fuel pressure 54psi.. hits 0 after 6 secs of turning off... ding ding
Old Jun 11, 2022 | 11:35 AM
GeorgeLG's Avatar
Now you have to determine if it’s in the tank or at the intake plenum.
George
Old Jun 20, 2022 | 12:59 PM
shonB's Avatar
So the fuel pressure tester was faulty. Using a new one the, pressure is at 55 while running and when shut off. 1 pulse of each injector with the snap on put the pressure at 45. Dealer said compression test was okay but need to confirm myself... truck is at work, most tools are at home... time is at a premium, but will update as i know more.. thanks again guys
Tommer2
Jan 14, 2019 09:07 AM
christine_208
Mar 30, 2018 02:31 PM
tycobb280
Aug 27, 2016 05:04 PM
merlindan
Nov 18, 2015 04:57 PM
blazerhelp01
Jun 13, 2015 04:33 PM
