2001ZR2 Crank Sensor Relearn
Old Jan 5, 2019 | 12:05 AM
Tommer2's Avatar
Tommer2 is on a distinguished road
Default 2001ZR2 Crank Sensor Relearn
Heres the deal. I replaced the crank sensor and did not do a relearn. It was running so good I didn’t think I needed too. It ran really well around town and an occasional one hour trip. I had one code a Po303 random misfire code. I felt nothing. Ran real well.
Now today I left Georgia heading to Ohio. Truck ran very well until about 300 miles. Every time I’d go up a big hill the trans would kick down and start to loose power. The tach would go crazy!! Finally it just had no power at all so I pulled it over. I had my code scanner with me so I plugged it in and got 9 codes. From p0101 to egr to random misfire to p404, P1870,P0741P0335. Well you get my point. I cleared all the codes and the truck then ran real well again. Ran it like that for another 100 miles then it lost power again with a couple of the same codes. Cleared them and it ran well again. Almost to Ohio and I stopped again and cleared another couple codes and yes ran well all the way to my destination. It’s a 2001 ZR2 4.3. By the way I averaged 16 miles to the gallon!! Do you think a crank sensor relearn will fix this? Sounds to me like the crank sensor is messing with the computer. Please help. Thanks.
Old Jan 11, 2019 | 05:06 PM
I think if they recommend doing it when you change the part, then theres no harm done... probably better off anyways.
Old Jan 14, 2019 | 09:07 AM
Agile's Avatar
Agile is on a distinguished road
I had an issue with my Tach going crazy, especially when it was over 3k RPM. Sounds like yours is doing the same. I put a shim on the Crank Position Sensor and have not had problems since. Did you get shims in your replacement crank sensor? If you did, did you install them?
Matt Evan Cinquini
Feb 11, 2019 11:01 AM
christine_208
Mar 30, 2018 02:31 PM
CCanter04
Jan 28, 2016 07:33 AM
Don850
Feb 16, 2015 05:57 PM
aquaman67
Mar 17, 2014 11:41 AM
