2001 Jimmy Just Cranking
Old Jan 10, 2011 | 04:32 PM
antman94's Avatar
antman94 is on a distinguished road
Thumbs up 2001 Jimmy Just Cranking
I bought a 2001 GMC Jimmy about 3 weeks ago and I didnt fill the tank yet untill yesterday. It was the first time I filled her up and 45$ later, I got home and tried to start it again, and it didnt start. I let it sit for 15 minutes and went back out and it started up. I then pulled it into the garage and polished the headlights. I went to start it up when I was done and it hasnt fired up again. Im pretty sure its my fuel pump because I dont hear it running when I turn the key. I just thought it was weird that It died once I filled the tank. Could it have been the strain of the full tank? I just wanted to know if there was anything else I should check before I go about replacing the fuel pump. Thanks in advance
Old Jan 10, 2011 | 09:16 PM
They rarely die when the tank is empty!
I would test fuel pressure to make sure that is the cause. As well as checking for proper power and ground at the pump.
Old Jan 11, 2011 | 02:07 PM
antman94's Avatar
awesome thanks alot, Il check it once this snow goes away.....
zdog
Nov 25, 2012 05:03 PM
mtone132000
Feb 26, 2009 06:30 AM
allbusiness2
Apr 16, 2008 05:59 AM
vagnozzi
Apr 17, 2007 08:29 PM
