2002 4.3 2wd oil leak...
So during my oil change to day I noticed the mount where the filter screw's in at as well as the pan was covered in oil. I just replaced the oil cooler lines a few months ago! Any other ideas where it could be coming from? Cleaned the area as best I could but still can't really pin point it.
Not really. Anything that can be done to remove heat from the engine that is not needed only helps the life of the engine. All gasoline engines can benefit from oil coolers, it is that the lines they use could have been a better design and higher quality.
ThatGirl1971
Oct 8, 2013 11:24 AM
