2002 4.3 2wd oil leak...
Old Dec 19, 2014 | 04:02 PM
fletch125's Avatar
fletch125 is an unknown quantity at this point
Default 2002 4.3 2wd oil leak...
So during my oil change to day I noticed the mount where the filter screw's in at as well as the pan was covered in oil. I just replaced the oil cooler lines a few months ago! Any other ideas where it could be coming from? Cleaned the area as best I could but still can't really pin point it.
Old Dec 22, 2014 | 11:15 PM
fletch125's Avatar
I would suggest that everyone stay away from any dorman products. The oil cooler lines i replaced last year were leaking from the press fit seals on the rubber portion! Only after a year of service! Replaced them with ACdelco ones so we'll see how this goes. Pretty silly to use oil cooler lines on a 2wd truck with no tow package
Old Dec 24, 2014 | 12:53 PM
Gregg64's Avatar
Gregg64 is on a distinguished road
Not really. Anything that can be done to remove heat from the engine that is not needed only helps the life of the engine. All gasoline engines can benefit from oil coolers, it is that the lines they use could have been a better design and higher quality.
JayTalbott
Aug 4, 2014 12:15 PM
ThatGirl1971
Oct 8, 2013 11:24 AM
mrgreazm0nkey
Jan 16, 2011 02:16 PM
tmar04
Jan 2, 2011 03:11 PM
TAZ454
Jan 28, 2008 10:11 AM
