2002 4.3 will not start
Old Sep 29, 2012 | 10:14 PM
neal's Avatar
neal is on a distinguished road
Default 2002 4.3 will not start
i have a 2002 blazer with 4.3 motor, today i had an over heating problem got up to 250. blazer died, let it cool down when it started it ran real rough and had no power. drove it a couple of miles died again. let it set for a few minites, started it again drove a few more miles died again. traliored it home. truck will not start, turns over just fine, checked fuel pressure its 50#, checked spark got plenty. but still will not start. any ideas will help, thanks
Old Oct 1, 2012 | 10:50 AM
igs4dragon8's Avatar
igs4dragon8 is on a distinguished road
check your ignition coil
wean hot
Old Oct 1, 2012 | 11:04 AM
Lanny's Avatar
Lanny is on a distinguished road
Run a fuel leakdown test...key on engine off you should have 60psi and no less than 55psi after ten mins.
Spark should be brilliant blue/white. Yellow/orange spark will not work.
As for overheating ;
Start with the basics. Exchange the coolant. Be sure to burp the system. Next step would be to replace your thermostat.
good luck
Old Oct 3, 2012 | 03:34 PM
neal's Avatar
found the problem it was the cam positioning senser in the distributer, rplaced it truck starts and runs fine again.
skygodtj
May 23, 2012 09:08 PM
stschuyler25
Nov 21, 2010 09:34 AM
wayland
Dec 9, 2009 12:38 PM
blazerJim1701
Jul 26, 2009 09:18 PM
