2002 blazer cursed with the dreaded p0300
its good enough to not misfire. If still setting P0101 please also report MAF reading at idle, and
then at full throttle 1-2 shift.
I don’t have a scanner capable of doing that at the moment.
If you scanner will display live fuel trims, then I bet it will display MAF reading. Maybe check some more for the MAF PID? It is a basic OBD2 function, just like fuel trims. Alternatively you can get one of the scanners that I mentioned.
So lets concentrate on the P0101 please by the MAF values at the two RPMs.
Best wishes
Nope - idle test is just idling in park. The other is watch for maximum MAF during full throttle 1-2 shift (should be at about 4900 rpm). Just nail it while in drive, from a 20 mph roll and watch for maximum MAF as it shifts. We're looking for around 5 g/s at idle and then more than 135g/sec at full throttle shift. That will be the range of your MAF. If units are something else than grams on your scanner, we can convert. Good luck!
so I just done that test. At idle it’s showing .755lb/min and the 1-2 shift is 16lb/min
