2002 security issue
Old Jan 27, 2009 | 09:01 PM
red/white04's Avatar
red/white04 is an unknown quantity at this point
Default 2002 security issue
Security light stays on. Starts and then stalls. No dome lights or door chime. No DTCs. Did the Ignition Switch replacement, Still no change. Did the relearn...still nothing..Checked all the fuses...and still nothing. Bought it cheap(like this) its in really nice shape...just need to get it running......I've did a search and nothing seems to match my problems exactly....PLEASE HELP ME!!!!!
Old Jan 27, 2009 | 09:34 PM
rriddle3's Avatar
Default RE: 2002 security issue
Does it (or did it) have an aftermarket security system on it? Have you tried a 30 minute battery disconnect?
Old Jan 28, 2009 | 07:05 AM
Classic ignition switch or passlock failure. Does it start if you try it 5 times and then wait like 10 minutes until the security light turns off.
And yes, I too would suspect some aftermarket equipment aside from a possible bad replacement ignition switch or botched installation.
Old Jan 28, 2009 | 07:17 AM
Nope, just the factory stuff...no aftermarket..( i swapped an ignition switch out of a smashed 2000, and no difference: but the one i took out of the one i'm fixing i pulled into the parts blazer and it runs...this tells me that the one i took out of my blazer is not bad and not the problem....would the cylinder key cause the same thing? a bad BCM? I could take the computer and BCM out of the running Blazer(2000, frame was too far gone to fix) and put it into my not running 2002 would this work or would it be more conflictions?
Old Jan 28, 2009 | 07:36 AM
Depends on what your 2002 truck has for options and the engine controls (engine changed mid-02). You do realize that pulling parts off of another year is an iffy thing... Why not just plunk down the $50 or so and buy the proper part.
Old Jan 28, 2009 | 08:03 AM
cus i have the other blazer for parts...if i can use the parts off that i will..if i can't then i will have to buy them
Tony H
Sep 14, 2012 12:22 AM
brad2012
Sep 3, 2012 06:21 PM
warthogdriver
Aug 28, 2012 07:48 PM
vlb6472
Jan 19, 2012 06:18 PM
Chris99
Sep 28, 2011 03:52 PM
