2002 Xtreme wont hold fuel pressure
Hi, I have 2002 Xtreme 4.3 it looses fuel pressure I replaced fuel pump assembly 2x, new filter ,regulator 2x and if I get the truck running it will go all day but if it sits for a hour or more I play hell to make restart not sure where to look from here any help will be greatly appreciated. ps I think the spider too.
I'm assuming you have done a leak down test since you say it's losing pressure correct? You can try looking through the TB and see if there are any "washed" spots from leaking fuel in the intake. There won't always be spots but its a cheap easy place to start. Leaky spiders aren't uncommon in these things do some searching and you will find all kinds of info on the subject
Thank you for the reply"s yes i did the leak down test it seem to only get fuel while the motor being turned over, after no pressure. and the pump that in it now is oem ac delco. i will look at the tb.
thank for the reply I was wondering if anyone knows about the ball valve that some posted on here. I put one together in place of the filter and closed it when the fuel pump stopped and still looses pressure quickly 60 - 0 in a few seconds should it keep pressure from the tank to the valve?
I replaced the spider and have fuel pressure, now it goes to 60 and drope to around 55-50 and holds but still no start, i put a ball valve in place of the filter to check leak down will the filter not being in place cause it not to start?
As long as the ball valve is open, and fuel can pass through it, there should be fuel pressure at the service port.
With the ignition in the OFF position, connect a jumper wire from battery positive to the fuel pump prime terminal in the underhood fuse panel.
When the fuel pressure stabilizes, it should be 60psi to 66psi. Remove the jumper and pressure must remain above 55psi for at least 10 minutes. Post your results.
