2003 Blazer - No 2nd gear
Old Nov 4, 2009 | 12:16 PM
OrionSS3's Avatar
OrionSS3 is on a distinguished road
Default 2003 Blazer - No 2nd gear
Help anyone...I took my blazer to a transmission shop. The owner said I no longer have a second gear in my automatic transmission. Would it be better to find another transmission from a junk yard and replace it myself or should I have this shop fix it for $2,000?
I am an airplane mechanic, but I do not know anything about automatic transmissions...should i rebuild it myelf, and if so what is going to be my cost?
Old Nov 4, 2009 | 01:13 PM
Are you sure that 2nd gear is all that is affected?
Old Nov 4, 2009 | 01:23 PM
OrionSS3's Avatar
Default No 2nd gear
That is what the transmission shop said. I drive the blazer everyday. When I put it in drive...no problem. When the Blazer tries to shift, it just keeps reving up to about 4500-5000 rpm then it "seems" to catch. I am guessing that it is catching 3rd gear and missing 2nd all together. I took it to a shop and they hooked up a monitor and drove it. They came back and said I had no second gear...That is where I am at with it now.
Old Nov 4, 2009 | 01:38 PM
I would bet that there is more to it than that. 2nd cannot just go out all by itself. It is possible that the 2-4 band is toast which would take out both 2nd and 4th. There is also the possibility that the 1-2 shift solenoid is some how messed up.
It also could be a malfunctioning shift B solenoid which would take out 2nd & 3rd and is an easy fix in the pan.
A harsh or delayed shift into 2nd could also be caused by a malfunctioning throttle position sensor.
Old Nov 4, 2009 | 01:43 PM
OrionSS3's Avatar
Default No 2nd gear
Thanks for your help. Sounds like I need a second opinion...or possibly as third (with your advice). I will check into other shops to help diaganose this issue....Thanks again!!
badge4279
Sep 26, 2010 06:28 PM
stepjl
Sep 25, 2010 12:17 AM
75 blazer
Aug 13, 2010 06:36 AM
BOTTLEDZ28
Dec 3, 2007 08:18 AM
