2005 PCV location on 4.3L V-6
Old Jan 1, 2010 | 01:03 PM
2005Jimmy's Avatar
2005Jimmy is on a distinguished road
Default 2005 PCV location on 4.3L V-6
Has anyone changed the PCV valve on a 2005 Jimmy? All I can find is a hollow thin metal tube where the PCV should be on the left valve cover. It's not like the 2000 Jimmy I had where the PCV is on the valve cover. The 2005 hookup connects to another fitting nearer the throttle body and looks like the setup for a PCV on a 3.8L V-6 (2003 Monte Carlo) but I can't find a PCV inside.
They sell the old PCV at a parts store for the 2005 but it won't fit the smaller opening.
Any help would be appreciated.
Thanks.
Old Feb 12, 2010 | 12:46 PM
2005Jimmy's Avatar
I finally got to GM parts counter and got the guy to look it up. It shows the routing to a metal sleeve on the rocker cover (as I see on mine). There is no PCV valve on the 2005 4.3L V-6 just in case anyone else goes looking for it. The 3.8L V-6 has a similar setup but does have a PCV valve under the cover on the end of the block near the serpintine belt.
2005Jimmy
Old Feb 12, 2010 | 02:28 PM
1997 red blazer's Avatar
1997 red blazer is on a distinguished road
Hummmmmmmm, are you sure? does it look like the valve cover on your 2000 ? But has no rubber Grommet right ? But hard build up were the PCV would go ? But with the Small Metal sleeve in the cover, If you pull it out it is a PVC but just way Smaller and it is Locktied in. Hope this Helps? Check it out let us no what you find? Remember to locktite(sp) it back in though. T.J.
joejiz
Mar 30, 2021 02:53 PM
Dustyrandall
Jan 26, 2013 06:28 PM
joejiz
18
Nov 14, 2012 03:31 PM
Tonyrodz
Jan 26, 2012 04:57 PM
jerryh20
TrailBlazer GMT360/GMT370 (2002-2009) Tech
Jun 4, 2007 04:06 PM
