2wd vrs 4wd Engine
Old Jun 6, 2022 | 03:41 PM
kevinlsimmons's Avatar
kevinlsimmons is on a distinguished road
Default 2wd vrs 4wd Engine
I am working on my 94 4.3 type w and I am getting a persistent code 42. I tried to replace the ECM but that didn't resolve the code. But my question relates to the differences between the 2wd and 4wd. The reason is because I used the body from a 4wd to restore my 2wd truck. So when the body was swapped the factory ECM in the 4wd was used. I'm sure that mechanic did not take the time to swap the ECMs.
When I replaced the ECM i purchased one for a 2wd model. But the PROM I reused would be the one that came out of the 4wd. Are there actually programming differences between the 2 models? Would using a PROM from a 4wd create a problem? Are they any differences with other sensors?
Old Jun 6, 2022 | 05:05 PM
I can say that the wires alone are different from 2wd to 4wd in the dash. So I'm gonna assume that the ecm is different. Just because they need different programing for power output during shifts... if they use that... I'm going out on a limb here lol...
But I could be making an *** out of u and me........
Old Jun 6, 2022 | 05:23 PM
Thank you! Well, if the wiring is different then it stands to reason that the pin assignments are different, too. I might need to try the 4wd ECM since that's def the wiring in the dash. The engine and sensors are from the 2wd.
Old Jun 6, 2022 | 05:43 PM
To whative come across. If they came from the same year, the engine should be the same, so the wires should be the same... difference mostly came for that trans and 4wd
swartlkk
Feb 6, 2025 09:57 PM
Jimmy_Blazer
Jan 27, 2017 05:44 PM
puttster
Suspension Tech
Sep 1, 2015 06:01 AM
bobbot
Apr 30, 2009 02:47 PM
nadaoriginal84
Jun 25, 2007 10:28 PM
