#3 plug ok to leave?
Ok I changed my plugs the other day and the plug wear wasnt that bad the only plugged I didn't want to struggle with was the #3. Is it ok to leave the delco that was in there that should be like the others I removedand only shows some wear or should I really try to get that out and replace it with the Bosch Platnium Plus that the others have now?
Yah hopefully they will be fine I saw other places that said they were fine. It may be due to the larger gap in the Bravad. My Bravada has a .060 instead of the .045 ive seen for the blazers and s10s. I dont plan on having it too much longer anyway its getting old so they should last that long.
I would remove all old plugs regardless of what wear it may have on it. Different plugs will effect the rate of spark no matter how simliar they may seem. Your Delco plug will not fire at the exact same right as the Bosh's. If you leave it in there with new plugs then you may run into a failure rate quicker than normal. If your having problem with the number 3 plug becuase of the angle then remove the tire from that side and you can easily access it through the hole where that rubber pad comes down to prevent wheel well sludge from hitting the engine. Just lift that up and you should be good to go. I did that on both sides of my Blazer and it was a hell of a lot easier to access the plugs. Hope this helps.
#3 is the one behind the steering shaft, ive tried a wobble it wouldn't fit due to steering shaft, tried a closed end ratchet wrench and plug socket wouldn't fit due to heat shield. I don't think removing the rubber steering guard will gain me enough and I dont want to try to remove the steering shaft.
Use a plug socket with a shorty closed end wrench, crack it loose, then through the wheel well, with wheels turned to the right for more room, stick a piece of rubber fuel line (about 6-10 inches long) on the plug and spin it out. The hose trick works on many vehicles when you can't get your hands where you want them. Reverse procedure for install. This takes me less than 10 minutes. I would not un-hook stearing collum.
