350 starting
Old Apr 14, 2007 | 08:12 PM
74green's Avatar
74green is an unknown quantity at this point
Default 350 starting
I just recently rebuilt my 350 for my 79 K5. Cannot get the truck started. Backfires thru carb/intake. Have adjusted the dist many times to try and resolve issue, but cannot get it started. Heads/valves are adjust correctly.
Any ideas??
Old Apr 15, 2007 | 02:18 AM
Hanr3's Avatar
Default RE: 350 starting
Your positive you have the distriburator timed to the compression stroke and not the exhaust stroke?
That would be the first thing I would check. Pull the distriburator out, crank the engine over to TDC and try it again. If you pulled your timing cover you could verify TDC, but that is some extra work.
Old Apr 16, 2007 | 03:13 PM
1badblazer's Avatar
1badblazer is an unknown quantity at this point
Did you remeber to turn the key? that helps me out when I want to get it to get up and go
Old Apr 16, 2007 | 06:26 PM
Chevy Lover's Avatar
ORIGINAL: 1badblazer
Well I guess we'll just ignore 1badblazer as he appears to be just passing through.
74green, have you tried to static time the distributor? It sounds like either the timing is out or the firing order is incorrect.
Old Apr 16, 2007 | 08:25 PM
ethos's Avatar
ethos is an unknown quantity at this point
Ok first pull the dist. then pull the number one plug(first plug on drivers side) have a friend bump the motor over while you hold your finger over spark plug hole, when it blows your finger off stop. nowlook at your timing mark on the balancer bump it around till you hit the 8 deg. mark on the timing tab (if you go past just turn it back by hand)then redrop dist.when the dist. is all the way down the rotor should be pointing towards the number one plug hole (in that general direction). just fired mine for the first time and thats how i do it on every motor
Old Apr 16, 2007 | 11:50 PM
Hanr3's Avatar
Good post for your first one. [sm=exactly.gif]
Welcome to the site. [sm=happy046.gif]
tech180
Feb 2, 2013 10:23 AM
cgrett
Nov 15, 2010 09:08 PM
Sprocket
Mar 20, 2008 09:39 PM
JVS
Mar 8, 2005 09:00 PM
slingshotmb
Feb 20, 2005 12:57 AM
