88 350 5.7l blazer will start and then die
Old Mar 7, 2005 | 02:21 AM
JVS's Avatar
JVS
JVS is an unknown quantity at this point
Default 88 350 5.7l blazer will start and then die
I have an 88 blazer (full size) that will start and then die after idling for 2-3 minutes, sometimes less. We have changed everything we can think of. (fuel pump, fuel filter, ignition switch, relay switches, etc., etc., etc.) We've taken the fuel lines lose and blown them out. We've bought a new fuel tank, and changed the pump. Once I figure out what is wrong with this thing, I'll basically have a new truck...just 'bout everything has been replaced. Sounds like a fuel problem, and possibly the fuel pump, but it has been replaced??? Do you think the aftermarket pumps don't give enough umph to keep the injectors going? Help me please. I'm losing hair and sleep.
Old Mar 8, 2005 | 09:00 PM
zero psi's Avatar
Retired Admin
zero psi is an unknown quantity at this point
Default RE: 88 350 5.7l blazer will start and then die
i had the same problem with mine when i first got it. my egr valve was stuck, so i shot some wd40 in it and moved it up and down. that was over a year ago and it hasen't caused any trouble since.
barnesto
31
Jun 11, 2014 07:12 PM
david068513
13
Aug 14, 2012 09:47 AM
Jetpack_Ahoy
16
Apr 5, 2012 06:03 PM
Psychropod
Apr 12, 2010 05:50 AM
dozerman
Sep 23, 2007 05:05 PM
