4.3 engine out of a 2001
Old May 8, 2018 | 02:32 AM
dodgeman137's Avatar
dodgeman137 is on a distinguished road
Default 4.3 engine out of a 2001
hello I have a 1996 blazer 4wd with a 4.3 and I need to know if a 4.3 long block out of 2001 blazer will work in my 96 thanks
Old May 11, 2018 | 07:46 AM
LesMyer's Avatar
Only issue is the knock sensor mounting hole may be different. 2001 is the year where they changed knock sensors - midyear I understand. Other than that, switch all the manifolds and other stuff from your old motor and you are golden. There are adapters specifically for the knock sensor problem. I have not used any of them but here is one that would adapt your old sensor to a later block if there is a need. https://www.google.ca/search?q=knock...eLz4iBbfpVwytM: You will need to have a crank sensor relearn done after all is finished to store info for the new setup, or the SES light may be on with a P030x code. Good luck!
Old May 11, 2018 | 05:40 PM
Default 4.3
Thanks I will check it over good before I install
muskyjoe
Apr 19, 2011 07:39 AM
redbone44
Jan 20, 2011 11:36 PM
SureShooter29
Mar 18, 2010 03:02 PM
Bybsurfr32
Nov 1, 2009 06:50 PM
