2001 Blazer LS ZR Front ends pops out 4-whee drive briefly when towing under strain
Old Jan 19, 2011 | 09:16 PM
redbone44's Avatar
redbone44 is on a distinguished road
Default 2001 Blazer LS ZR Front ends pops out 4-whee drive briefly when towing under strain
2001 Blazer LS ZR 3-button on dash, 5-spd. when towing snowmobile trailer up hills front end pops out briefly- does not sound good at all, had to put into 4-low to continue up hill. any ideas where to start?
Old Jan 20, 2011 | 10:17 PM
KM346's Avatar
KM346 will become famous soon enough
Ill take a guess and say its probably your front axle disengaging when under load. The front axle is engaged via a vacuum actuator under the battery tray which can go bad and cause an issue like this. There is also a cable that could be kinked or damaged that goes to the axle tube itself. I would grab a buddy and get under the truck to see if this cable is engaging properly when you push 4wd. A lot of people use the "posi-lok" manual locking cable instead of repairing the actuator, I plan on installing one if/when i have issues.
Old Jan 20, 2011 | 11:36 PM
jbsnowboarder16's Avatar
jbsnowboarder16 is on a distinguished road
A plain vacuum leak could be causing the problem also, like KM346 said, the axle engages via vacuum so if you have a leak somewhere, it will pop out because the vacuum to the actuator goes away
Shaggy
Jul 30, 2010 09:03 AM
Chevy Nova
18
Jun 4, 2010 06:46 PM
swizznuker
Feb 18, 2010 05:06 PM
cide
Aug 9, 2009 08:02 AM
chigger
Dec 31, 2007 12:50 PM
