4.3 s10 blazer w
4.3 s10 blazer w
blazer wont start cranks like a champ I replaced entire fuel system from spider 2 fuel filter to fuel pump and I replace the engine cool distributor cap pickup coil and engine control module ignition control module still I can't get it to start
but did you actually check fuel pressure, good spark. no major vacuum leaks, proper cranking speed, No security light, etc.?
Also, Model year, Mileage, Describe "cranks like a champ" because mine did that plenty well but there were some telling signs in the sound as to why it refused to start.
sucking massive amounts of air from around the plenum, actually, to the point that you could hear it whistling if you got close enough.
