4.3 timing chain and oil pump ?????
Old Mar 6, 2008 | 09:12 AM
jamon8's Avatar
jamon8 is an unknown quantity at this point
Default 4.3 timing chain and oil pump ?????
is the timing chain and the oil pump the same as a small block chevy on the 4.3
Old Mar 6, 2008 | 09:17 AM
jamon8's Avatar
Default RE: 4.3 timing chain and oil pump ?????
is the 92 4.3 a roller block
Old Mar 6, 2008 | 09:41 AM
It is possible to have the same timing set and oil pump, but the only reason I would think someone would ask this is if they were trying to find a used set to install. I would highly advise against this. If you are going to go through all of the work to install these parts, I would not put in used components...
And what do you mean by roller block? Rockers - No. Lifters - don't think so either.
kancop
20
Feb 19, 2014 04:33 PM
castnhope
Mar 5, 2012 05:10 PM
99blklt4wd
Dec 15, 2011 05:00 PM
drblaze
18
Jun 22, 2011 01:58 PM
2001blazer
Nov 10, 2006 12:48 AM
