4.3 vortec engine swap into 85 4x4 s10
Old May 10, 2007 | 06:44 PM
Shade's Avatar
Shade is an unknown quantity at this point
Default 4.3 vortec engine swap into 85 4x4 s10
hey i have the 2.8 v6 in my 85 and i want to put the fuel injected votec 4.3 in it. like a 1993 s-10 4.3engine or something. is this a semi-easy job to do? or would i have to make a ton of modifications.
Old May 10, 2007 | 08:32 PM
Shade's Avatar
Default RE: 4.3 vortec engine swap into 85 4x4 s10
bump?
Old May 10, 2007 | 08:59 PM
Have some patience... Geez...
A 2.8L is a 60* V6 while the 4.3L is a 90* V6. The transmission bolt patterns are completely different. So you'd need a transmission for a 4.3L to make it work.
If you were to find a v8 transmission, why not just go straight to a carb'd V8?
Old May 10, 2007 | 09:26 PM
Shade's Avatar
well because i dont want all that weight in the front, i want to raise it 6 inches and so on, i just want the extra power that the early 4.3 has. and i knew the bolt paterns were different on the trans so im exspecting to get an auto from the same vehicle that i get the engine from, if its good. so basically off the top of my head and the knowlage that i have about cars and trucks, i would need the full engine. and if it doesnt have a clutch fan, ill need the elect fan, and ill need the full computer of course becuase of the fuel injection... and ill need the tranny. so basically im asking, what else do i need to do, like are the engine mounts the same? will i have to cut room for the exaust manafolds? will i need to buy a new catelytic converter to pass smog? stuff like that. i have a brand new cat on this blazer with a2.5 inchsingle flow master, is that good enough? or will i have to go bigger?
Old May 11, 2007 | 09:03 AM
drperry's Avatar
motor mounts, fuel pump, wiring harness, transmission, radiator, trans cooler... Pretty much everything that's used to make the engine run, you'll need from the donor...
And a 350 will be pretty close in weight to the 4.3...
Old May 11, 2007 | 04:11 PM
Shade's Avatar
hmmm i see, so to do this im basically going to have to buy the whole donor truck and just strip it lol. thanks for the info
Old May 11, 2007 | 04:47 PM
drperry's Avatar
That's probably the easiest way to make sure you have all the parts...
Carb to carb is a whole lot easier than carb to FI... Heck, even FI to FI swaps can be annoying, unless you're going to a better condition version of the same engine...
Old May 11, 2007 | 09:47 PM
Shade's Avatar
well mine as you might already know is a computer controller carb? only thing i can adjust is the idle... that and i HATE carberators because every vehicle ive had that has had one, always had a vacume leak inside of the damn thing.
Old May 12, 2007 | 04:36 AM
drperry's Avatar
It's electronically controlled... not so much computer controlled... It's an electric choke that the carbed 2.8 has.
I had an '85 S10, so I looked into all that...
Old May 13, 2007 | 04:39 AM
Shade's Avatar
oo thanks for that info, yea everyone was telling me its a computer controlled carb, so wait if iperformance chip the computer, what is it going to do for me?
