4.3L, both injectors fire at idle?
Hello. My first time posting here, can nomarlly find me over at stangnet.
I just bought a 91 S10 4x4 Blazer with the 4.3L V6, fuel injected of course. The guy I bought it from thought the fuel pump was bad, so I did some checking, and turned out that the ECM fuse kept popping due to the green injector wire being pinched. I fixed that, and bought a new injector.
Are both injectors supposed to pump fuel at idle? The reason I ask is, it's running very rough with no power. I haven't really had time to troubleshoot anything else, I just bought it and limped it home today. Any help would be greatly appreciated.
-- Rick
-- Rick
Well you said that you fixed one of the injector wires, I would check the other wires by the injectors. It is possible that the injector driver in the ECM got shorted when the wires got pinched. This is a pretty crude FI system. Not allot there. The injectors have constant power from the ECM fuse that kept blowng, then they are supplied a ground by the ECM. I would check the integrity of the wiring from the injector to the ECM. I would also just make sure that the new injector is not bad, I have seen that before. To check the injector driver and circuit quickly, with the injector disconnected, install a test light between the two terminals, and crank the engine.If the test light flashes then it is most likely the injector, but it still could be the driver, because the test light takes less power to fire then the injector. HTH Korey.
amp88fan
Feb 26, 2009 07:55 AM
BradensCreed
Nov 3, 2008 08:36 PM
