4l60e problems
Old Jan 25, 2009 | 11:05 PM
jeepmudbogger's Avatar
jeepmudbogger is an unknown quantity at this point
Default 4l60e problems
I have a '99 LT 4x4. I got a call from my girlfriend one day saying that the blazer wont go into reverse. I went and checked it out and sure enough it didnt go in reverse. We pushed it out of the parking spot and I jumped in it and took off home. It wont shift out of 1st until you get to 20 mph, and then it wont shift out of 2nd(or it seems like). I got up to 55 and i looked at the rpm's and they were up to almost 2500. when i pulled it in the driveway and put it in park the check engine light came on. so i checked the code and it was P0751. Shift Solenoid "A" performance of stuck off. i ordered the solenoids(i bought 2 for both solenoids just in case). I put them in, closed up the tranny and dropped the blazer off the lift, filled it up and still no reverse. as i was changing the solenoids i noticed the shafts that sit in the same hole that the solenoids go in(sorry i dont know the lingo, i dont know much about trannys). one felt like it had a spring behind it and the other one didnt, it was just laying in there. i dont know what could be the problem. i cleared the code in hope that it would pop back up again, maybe with a different code who knows. so far it hasnt popped up again but i was only driving it for about 30 mins. does anyone know what the problem may be? Thanks
Old Jan 27, 2009 | 01:33 AM
Ugly_Monkey's Avatar
Ugly_Monkey is an unknown quantity at this point
Default RE: 4l60e problems
Don't know about the rest but its normal for one piston to have presure but not the other. I had that scare when I changed some solenoids a while back, lol, but yah its normal.
Old Jan 27, 2009 | 06:00 AM
dksob81's Avatar
dksob81 is an unknown quantity at this point
sounds like your SunShell Gear is broke = time for a rebuild.
Old Jan 28, 2009 | 07:23 AM
so if i get a overhaul kit will it have the sunshell gear in it? whats the better kit that i can get?
Old Jan 28, 2009 | 07:37 AM
Doubt it. The Beast is the best sun shell to buy.
dj00140
22
Nov 4, 2015 05:03 AM
Sadchevy
Jan 29, 2010 08:26 PM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
