4L60E rebuild kits
Old Jun 21, 2015 | 06:07 PM
10-78 edac's Avatar
10-78 edac is on a distinguished road
Cool 4L60E rebuild kits
So my 98LE trans slips occasionally. It shattered my pinion gear and blew it out the housing. I got a new axle, put in new bearings and seals, works great. In the mean time I have felt the drivetrain randomly slip, once every two months. The original trans now has 165,000 miles on it. I picked up a used trans that had a new torque converter and pump installed within the last 10,000 miles. I want to tear down and rebuild the new trans so I feel confident with it for the next 150,000 miles or so. When i look at rebuild kits they range from $79 overhaul to close to $600 rebuild. My Question is, How much or what kind of rebuild kit would you use and why?
Thanks in advance for your input on this matter.
Old Jun 22, 2015 | 07:32 AM
newguy's Avatar
I used a mid priced for my truck. Have to think how long will the rest last? Butmoney was tight for me also.
Old Jun 26, 2015 | 09:56 PM
10-78 edac's Avatar
this is the one that has me interested has anybody delt with this guy?
4L60E Transmission Deluxe Overhaul Rebuild Kit 1997 03 w Filter Band Bushings | eBay
Old Jun 27, 2015 | 06:47 AM
newguy's Avatar
Looks legit, good price also
Old Nov 5, 2018 | 07:54 AM
Enet's Avatar
Enet is on a distinguished road
Thanks for sharing, and sorry for bumping!
__________________________________________________ _______________________
All the best: https://mechanicguides.com/best-4l60e-rebuild-kit/
Old Nov 5, 2018 | 08:34 AM
Transman304's Avatar
The kit is only a fraction of what needs addressed in an overhaul. Be careful with knock off parts and stuff from China. You are taliking like you want it to last so updates and known parts that fail that need replaced. Setting the proper clearance on build is critical VB wear is a huge issue on these units along with pump. I personally would look for a kit that used Borg Warner high energy frictions for the 3-4 pack. Just my opinion on overhauls. I get contacted after a DIY job won’t work after rebuild followed by a list of new parts installed. You can put hundreds of dollars of new parts in and destroy them in seconds. It’s not what you know in transmission repair it’s what you understand. This is a very doable transmission for the DIY just do your reasearch and don’t get caught up in the HP, super heavy duty parts lists that say you have to have them. Good luck and if you have any questions please feel free to ask. You may really enjoy transmission work, Lord knows we need some new blood in this industry.
Old Nov 6, 2018 | 04:34 AM
newguy's Avatar
https://www.gmtransmissionparts.com/...n-rebuild-kit/ this is the kit I used and just take your time, double check everything you do. Ask questions on here. It can be done by the rookie. I did it.
tar4heel2
Mar 22, 2014 08:47 AM
gatorboy44
Sep 17, 2011 08:22 AM
Ryanmatt135
Mar 23, 2010 08:24 PM
86blazeder
Feb 24, 2009 07:33 PM
walkingtall
Jan 27, 2007 05:08 AM
