4L60e Tranny action OVERDUE
Old Mar 8, 2010 | 02:04 AM
kiwiblazer's Avatar
Smile 4L60e Tranny action OVERDUE
Hey guys. Time to get my A into G LOL
I need to start the renovation of my spare tranny.
This is what I've got lined up on e-bay. Anyone dealt with any of these guys?
http://cgi.ebay.com/ebaymotors/GM-4L...item20af4b1a66
http://cgi.ebay.com/ebaymotors/700-7...Q5fAccessories
http://cgi.ebay.com/ebaymotors/TRANS...=item110d322f5
Am I about to order the right parts? Comments & or corrections/suggestions will be greatly appreciated.
Remember! I'm too far away to send this stuff back if it's wrong! LOL
Old Mar 9, 2010 | 01:30 AM
kiwiblazer's Avatar
Bump! Anybody?
Old Mar 9, 2010 | 06:36 AM
Those last two are what I will be putting in my Rainier at some point. Not too sure about the first one. Is this for your replacement trans? The newer transmissions were better in the valve body.
Old Mar 9, 2010 | 09:09 AM
AJBert's Avatar
I would definitely look into upgrading the sun shell, probably the weakest part of the tranny. Good choice on the Transgo shift kit and servos. Take a look at your valve body before replacing it. Yours may be good to go.
Old Mar 9, 2010 | 10:56 PM
kiwiblazer's Avatar
Yea Kyle. Plan is to do the upgrade to the replacement tranny then do the transplant.
Thanks for the reply & I'll be placing my order today.
AJBert - The valve body is what started this whole excercise. For 2 years I've been having the P1870 code trigger the check engine light. Figure by now the tranny is a bit worse for wear having left it so long.
EDIT: In respect of the VB I've asked the guy a question. Waiting now for his reply.
Old Mar 10, 2010 | 01:56 AM
kiwiblazer's Avatar
What's the "sun shell" ??
Old Mar 10, 2010 | 06:15 AM
It is a component about 3/4's of the way into the guts of the transmission. Some stock shells have weak splines where they engage the shaft.
Old Mar 10, 2010 | 09:22 AM
AJBert's Avatar
Here is an upgrade for the sun shell:
http://racetransmissions.com/store/p...roducts_id/692
Old Mar 10, 2010 | 09:26 AM
Yep, the 'beast' is the best one you can get. If you already have a transmission out, it isn't much for a shop to swap that in.
Old Mar 10, 2010 | 10:29 AM
Hanr3's Avatar
I dont see any parts to rebuild the tranny, as in the clutches, gaskets, seals, torque converter. Find a "High Energy" rebuild kit with kevlar clutch packs.
You should also look into the 4/3 kick down mod in the pump.
Couple of things to make your tranny live a nice long life, tranny cooler, temp gage, and drain plug. Drain it once per year and top off with new fluid. Heat is the #1 enemy of transmissions.
