4L60E Trans. No 2-3 Shift
Old Mar 8, 2013 | 05:33 AM
Jsimmons1970's Avatar
Jsimmons1970 is on a distinguished road
Default 4L60E Trans. No 2-3 Shift
My girlfriends 97 Blazer lost 2-3 shift yesterday. I just replaced this trans about 2 weeks ago since the other went south. It only has 125,xxx on it. She said it was fine then all of a sudden it would not shift to third, it just revved up. I had seen on some other post about 3-4 clutches burning out but can't believe it would go just like that. In some of the post I have read it was said to remove the plug from the trans and see if you have third gear mechnical to rule out failure in the clutches, I did this and it seemed to be in first rather than third because it would not bog down taking off in such a high gear. It also seemed that it would over rev some times when I had it unplugged as if third was actually out. Could it actually be a bad 2-3 solenoid or clutch failure or some type of wiring issue? When I replaced the trans the harness for the shift position sensor was cobbled together and damaged from rubbing the front drive shaft. I did fix it yesterday after finding one in the junkyard.This thing is driving me crazy because of little things.
Old Mar 8, 2013 | 01:24 PM
FTR85's Avatar
FTR85 is on a distinguished road
Most independent shops will offer a free electronics diagnosis. With the really high end scanners, the individual solenoids can be tested. I would have them take a look at the 2-3 solenoid before doing any more labor.
Old Mar 8, 2013 | 02:54 PM
newguy's Avatar
/\/\/\/\/\ agree/\/\/\/\/\/\/
Old Mar 9, 2013 | 12:12 PM
Well I discovered that it it's indeed the transmission. Went to salvage yard and found a 97 that was a rollover and got the solenoids out of it. Put both the solenoids in and still no 2-3 shift. So I'm going to pull it out tomorrow and take it back to get a replacement.
dj00140
22
Nov 4, 2015 05:03 AM
grounded87
Mar 25, 2011 06:36 PM
DrEaMsTeVe
Feb 15, 2011 02:50 PM
an240172
Sep 7, 2009 02:58 AM
95blazer8620
Oct 19, 2007 01:26 PM
